Mar 12, 2018 12:53 PM UTC
Change size of widget Javascript
 I wanted to know if there was a way to change the Height or Width of a 3d widget (eg Image3D) BY JAVASCRIPT.
I TRIED TO USE THE SYNTAX :
$ scope.size = function () {
$ scope.view.wdg ['3DImage-1']. height = 2;
 BUT NOT WORKING:
thnx
Giuseppe
ytellaAnswer
Apr 5, 2018 6:28 PM UTC
Hi Giuseppe,
Width and height are not currently dynamic properties. They cannot be changed after the image has been added to the scene. The closest equivalent you can use for this is 'scale' property.
ytella17-PeridotAnswer
Hi Giuseppe,
