change the color gauge 3D twx studio
hello, i have a question, is possible change the color of the gauge 3D with respect to value, for example if the value is 30 the color is green but if the value is 90 the color is red, is that possible?
with the gauge 2d is possible using value min and max but in gauge 3D is possible?
tmccombieAnswer
For more information on creating state definitions in ThingWorx, see the ThingWorx help center section: http://support.ptc.com/help/thingworx_hc/thingworx_8_hc/index.html#page/ThingWorx/Help/Composer/Visualization/StyleandStateDefinitions.html
Once you have the state definition defined, you can select it within Studio. I created a state definition called 'TaraTest': StateDef.png
I chose the dependent field of the state definition to be the text field:
Now when I preview, the gauge shows green for a value of 10 based on my state definition:
You can use state based formatting for the 3d gauge. Check the "allow state based formatting" box within the gauge properties. You can then select the state definition you created within the connected ThingWorx instance.
do you have a example? thanks for the answer
tmccombie21-Topaz IAnswer
