Feb 26, 2021 1:06 PM UTC
Changing state of toggle button during play started and play stopped events
Hello, I have a toggle button where pressed is play and unpressed is pause. While step is being played, the toggle button changes from play to pause and as soon as the step ends it changes back to play. Any other way to make this work apart from play started and play started events under model widget.
18-Opal
Feb 26, 2021 3:11 PM UTC
It might help if you can give a little more detail about where the event binding approach (play started/play stopped) is not working the way you would like. That's what I'd recommend for this, unless there's a specific reason it's not working for you.
