Oct 2, 2018 9:27 AM UTC
Changing View Issues
Platform: Hololens
I have encountered an issue with Studio when trying to change a particular View in Studio.
I have 5 Views (a, b, c, d, e) and in each I have enter the following code into the corresponding javascript file.
// Change scene
$scope.app.goa=function() {
twx.app.fn.navigate("a");
$scope.app.gob=function() {
twx.app.fn.navigate("b");
$scope.app.goc=function() {
twx.app.fn.navigate("c");
$scope.app.god=function() {
twx.app.fn.navigate("d");
$scope.app.goe=function() {
twx.app.fn.navigate("e");
I also have 5 Application Events (a, b, c, d, e) each with the corresponding function to load the correct scene e.g.
app.goa();
When I run the preview these application events work for all but 2 Views. And after clicking the Application Event to load a broken scene this prevents any other buttons from working.
I have also tried changing view without using javascript and relying on bindings but this leaves me with the same result. I have remove all other code form the .js file but still nothing.
Can anybody think of what could be going on here?
Many thanks.
Oct 2, 2018 1:58 PM UTC
What errors if any are you seeing in the console when you run in Preview? If you are using Chrome Shift+Ctrl+i will open the console for a tab.
Oct 2, 2018 2:17 PM UTC
In Short... A lot
I ran the application up until the point it stopped working.
I have attached the saved console log file for you. Hopefully it makes more sense to you than myself.
Thanks for the help.
Oct 22, 2018 6:47 AM UTC
Hi @jmikesell
Could you please reply on this. Thanks in advance.
Regards-Mohit
