Feb 4, 2021 7:07 AM UTC
checkbox does not fully shown
I have some checkbox in the right panel. When i preview the UI, the checkbox are not fully shown.
How can I solve this issue?
18-Opal
Feb 4, 2021 7:03 PM UTC
It looks like you have put these controls into the Right Panel in your 2D view. You may need to adjust the width of that panel to allow the full control to be visible.
Try setting this to 200px or 250px and see if that fixes your problem.
Feb 4, 2021 6:47 PM UTC
I have a question ;
  • How the Widgets are located ?
  • Is it by a css stylesheet or by a Grid Layout Widget?
By using a specific and custom css class, it might be possible to aligned that at right or/and to use width propertie.
More details here:
https://www.w3schools.com/css/css_align.asp
https://www.w3schools.com/css/css_dimension.asp
If it is Grid Layout Widget used, it is possible to use Fixed Column Size, Justification, Margin and Content Wrap properties to change that.
More details here :
http://support.ptc.com/help/vuforia/studio/en/#page/Studio_Help_Center%2FWidgetPropertyPanel.html%23wwID0EQGDS
http://support.ptc.com/help/vuforia/studio/en/#page/Studio_Help_Center%2FWidgetGridLayout.html%23
  • is it helping you?
Best regards,
Samuel
AS161-VisitorAuthor
Feb 5, 2021 12:28 AM UTC
Yes, I really appreciate it. thank you for your help 🙂
18-Opal
AS161-VisitorAuthor
Feb 5, 2021 12:27 AM UTC
18-Opal
Feb 5, 2021 2:21 AM UTC
You're welcome, glad it worked for you!
