Oct 28, 2019 1:49 PM UTC
Connecting Vuforia Studio with server/ local dates from Azure cloud
I want to connect a new project in Vuforia Studio with the Azure cloud. Therefore I have to install ThingWorx (TWX). According to an other questions in this forum, it is impossible to connect TWX trial version to Vuforia Studio (trial version).
Is it possible, that I copy the data from the azure cloud to a server or save them local and connect the project to those data, just using Vuforia Studio?
Thank you
dupatelAnswer
Oct 29, 2019 7:19 AM UTC
@Rapha97  If I understood your question correctly then I believe you are looking to directly use azure cloud exported data inside Studio Trail instance without using ThingWorx. This is not feasible with Trail instance as Studio Trial does not allow edit, import of data & entity.
In case you have your on-premise Experience Service & TWX then you can integrate your Azure cloud data or even import data into TWX which could then be used within Studio application.
-Durgesh
Oct 28, 2019 2:23 PM UTC
Hi @Rapha97 ,
because this question seems to be something like what is possible - therefore I want first to refer to the following helpful guide:
Use the ThingWorx Azure IoT Hub Connector with simulated appliances.
For example I have a test Thingworx server which is working on Azure Windows instance which is connected / used for an  Experience Service. In this case the Experience service also installed on the same azure windows instance.
But your Experience Service also Thingworx instance does not need to be installed in azure. It could be anywhere. It is required that the azure instance is visible for your   Thingworx installation and also that Thingworx is visible for the azure cloud.
Alternatively you can also use rest API for connectivity "Choose a Connectivity Method"
Rapha971-VisitorAuthor
Oct 28, 2019 2:32 PM UTC
Thank you for the fast answer.
Is there a way to connect Vuforia Studio (without TWX) to the exported data (e.g. SQL Database)?
Sorry for maybe asking dumb questions, but I am totally new to Vuforia
dupatel5-Regular MemberAnswer
-Durgesh
