AlessioAnswer
Oct 29, 2019 7:41 AM UTC
The ThingWorx instance included with the Vuforia Studio trial can be considered read only, that is you can use existing entities and read data from them but you are not allowed to create new entities
Oct 29, 2019 5:39 AM UTC
@Rapha97  Yes,  that is correct. Studio trail comes with an integrated  ThingWorx trail associated with it which could be used however that instance has some restrictions & limits.
-Durgesh
Rapha971-VisitorAuthor
Oct 29, 2019 6:23 AM UTC
Thank you.
Where can I find those restrictions & limits?
Oct 29, 2019 6:58 AM UTC
@Rapha97  You can log in to the Trial portal - https://trial.studio.vuforia.com/home/ and in the center, there is a Studio Getting started guide which has details. I am also sharing the direct link if that helps- https://s3.amazonaws.com/studio.thingworx.com/documents/StudioGettingStarted_Trial_en.pdf
-Durgesh
