Feb 20, 2019 6:26 AM UTC
Control Default SVG fill colors
Hi there,
I wonder is it possible to control Default SVG fill colors via CSS codes in STYLE\Application panel?
If I want to asign orange to resources/Default/vu_seq_play.svg <circle class="base">.
Is it possible?
Any reply would be appreciated.
ClarK
sdidierAnswer
Mar 9, 2020 12:57 PM UTC
I have created this article with an example about another solution :
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS321955
I recommend to use this one.
It is the simplest that I have found.
Best regards,
Samuel
Feb 22, 2019 12:16 PM UTC
@dsgnrClarK  I believe we cannot can change the style of SVG from CSS codes in STYLE\Application panel.  However, will check internally and review if there is a way.
-Durgesh
Feb 22, 2019 12:49 PM UTC
I was googleing this the other day and what i saw indicated that the only was to do this was to use JS to modify the svg data to change the color. Here is a thread discussing this; https://stackoverflow.com/questions/9872947/changing-svg-image-color-with-javascript
Feb 22, 2019 1:07 PM UTC
I have done the same thing by googling and find the same thread.
I have checked and started to investigate about this 2 days ago.
It is very tricky!
Let's me explain the various solutions and results in Vuforia Studio.
1. Solution A: Use a CSS stylesheet.
It cannot work because in Preview or in Vuforia View, Image Widget is an img HTML tag.
svg is embedded inside it.
To have a CSS who can modify svg image, it should that this svg is present as a svg tag in HTML page.
I didn't find a find to insert a svg like that in Vuforia Studio.
Strange behavior when using a CSS like that to an Image Widget and enter svg-icon in Class field :
.svg-icon {
 filter: invert(1);
Colors of svg are inverted as expected.
2. Solution B:
    It is in working in progress in my side.
    When running app, changing img tag to svg.
    a) Load this javascript library in Vuforia Studio in Resources :
         It can do the conversion from img to svg tag
         https://github.com/iconfu/svg-inject
    b) In javascript code:
        - Load the javascript library
        - Add an event on load web page to apply that on right img id.
$scope.app.fn.loadResourceScript("Uploaded/svg-inject.min.js");
$scope.SVGInject = function(obj) {
SVGInject(obj);
$scope.imageOnLoad = function(obj) {
console.log('here');
if (window.event.path[0].tagName=='img')
console.log('image');
$scope.SVGInject(this)
     Saddly, this code doesn't report no error or warning.
     It seems like event is not fired.
     - After that, a CSS stylesheet will be enought to change the fill attribute of path tag in svg.
3. Use build-in angular solution about that:
    I have found this web page about that.
    https://blog.akquinet.de/2014/02/26/interactive-svg-with-angularjs-part-2/
    I didn't dig up more about this solution.
    It is the best if it is needed to update in many colors the svg with values from Widgets and values entered by end-usr.
Best regards,
Samuel
sdidier17-PeridotAnswer
Best regards,
Samuel
