Could Thingworx studio work with other IoT solution ?
Hello every one,
Could Thingworx studio work with other IoT solution (other than thingworx foundation) ?
my customer already have an IOT solution and he wanted to know if he can use thingworx studio with his solution.
Thank you,
ThingWorx has a connector to Azure IoT and AWS IoT - so these two can be connected with these connectors. You can find the connectors on the MarketPlace (AWS) or on the PTC Software Download pages (Azure). If they are using other device Clouds, check out the marketplace for these as well.
As per my knowledge; currently ThingWorx studio can connect to ThingWorx foundation only.
But if the other IoT Solution allow REST calls; ThingWorx can be used to make REST calls to that system to fetch the data which can be used in ThingWorx Studio.
I hope it helps.
relqomri1-VisitorAuthor
Thank you all
Hi RACHID EL QOMRI​,
Could you please mark helpful and correct answers to close this Thread and let other member know that this Thread has some solution.
