Aug 3, 2018 11:13 AM UTC
Create a double-motion sequence in Illustrate
- 3 replies
- 3082 views
- Translate All
Goodmorning everyone,
I would need to create a sequence with the lifting of a double bulkhead, so I have to apply two movements at the same time on the same object (upward translation and rotation).
I created the movement with Parametric through the pin, slide and cylinder connections.
Now I would like to bring it or recreate it in Illustrate to create the sequence to use in Studio (see video).
Is it possible in your opinion?
Below is also the link that contains the .pvz with the movement (not real) that I managed to create in illustrated. (Figure: opening_port_dx) https://we.tl/m6g5JpWGMm
Thank you,
Matteo.
Thank you,
Matteo.
