Feb 6, 2020 10:02 PM UTC
Create Model Target in Code and/or Delay Object Recognition
We have some models that we're trying to do object recognition with the model target widget. The object though is very parallel, flat, and fairly un-interesting other than a handful of holes cut into it. With it being such a simple model, it tends to track onto the wrong area, or even other things in the environment that are parallel. (we're trying to avoid using a magnetic ThingMark or Image Targets in this scenario)
What we'd like to do, is keep the outline image up (I could re-produce that part if necessary), but not actually start the model target scanning until a button has been pressed once the user has lined up the outline. The thought being that it's more likely to latch onto the correct placement if it's already aligned once scanning starts.
One option, would be to create the model target on the fly in code. Though I haven't been able to find any examples of doing that.
Second option, would be functionality on the Model Target Widget that turns the tracking scanning on/off. Or even just on, if it started in an off state.
Any help or suggestions would be greatly appreciated.
Feb 17, 2020 12:04 PM UTC
Hello ghoofman,
You could try to use 2 views for you experience. Start with the view that contains the outline image that you reproduced and the button that the user needs to press. Then, when the user presses the button, you switch to the view that contains the model target.
Kind regards,
Lorena
