Jun 30, 2017 4:31 AM UTC
Create multiple pvi files in one pvz file in creo illustrate
I want to make multiple sequence files in one pvz file. Can anyone please tell me how to do it?
Dipika
sdidierAnswer
Jun 30, 2017 9:22 AM UTC
Hello Sengupta,
In Creo Illustrate, a Figure can only have one sequence.
So, to have more than one sequence, it is needed to create a new Figure.
To do that, in the Figure tab, click the New Figure button.
In the .pvz file, two .pvi files are present.
In Thingworx Studio, both sequences are available.
I hope that it will help you.
Best regards,
Samuel
sdidier17-PeridotAnswer
Hello Sengupta,
Best regards,
Samuel
Jul 3, 2017 6:36 AM UTC
Hi Samuel,
It worked!!  Thank you...
Dipika
Jul 10, 2018 6:47 PM UTC
Hi Samuel,Dipika
Good Day!
I have created 2 figures and used File > Publish > Publish Separate Files. I obtained 2 .pvz files however, I can not see .pvi format.
Could you please help me with the command flow.
Thank You
Ravi A
