Jan 10, 2018 2:02 PM UTC
Creo Illustrate product code invalid
hi,
i tried to install the Trial version of creo illustrate using the product code VS420607ED1040-YJWM-KD98
but the license setup says the product code is invalid
please help
Jan 15, 2018 10:07 AM UTC
ROHIT SANKESHWARI​ : In case the issue is still open then could you please provide the source detail from where you are trying to install Creo and the version you are planning to install ?
-Durgesh
Jan 15, 2018 10:16 AM UTC
Durgesh Patel​
thank you for your reply
I am trying to install Creo Illustrate and not Creo from the below link
http://support.ptc.com/WCMS/files/170678/en/StudioGettingStarted.pdf
please refer to page 20 of the above document
Page 23 is where the product code is mentioned.
Jan 15, 2018 12:01 PM UTC
Thanks Rohit..... Did you used the PTC Installation Assistant to retrieve and install a license by downloading and running https://free-dl.ptc.com/install/setup.exe.
Please make sure you do not have white spaces while copy pasting product code.
-Durgesh
Jan 15, 2018 10:20 AM UTC
Remove all the existing .dat files from the directory below and then try installing creo .It would be better if you use ptc installer hence it auto fetch the license.
C:\ProgramData\PTC\Licensing
Jan 16, 2018 1:18 PM UTC
Naveen Sankar​Durgesh Patel​
thank you for all your help.
I was able to install the trial software.@
