Dec 5, 2017 11:28 AM UTC
Creo Illustrate to TWX Studio issue...
I am seeing a slightly unusual problem with importing from Illustrate into TWX Studio. In Illustrate, if I import additional assemblies into a project and then save that project as a .c3di and then publish as per normal in .pvz, while this saved .pvz displays perfectly in Creo View Express (as in it shows the additional assemblies), when I import the same .pvz into Studio, all I get is the original project without the additional assemblies.
The Studio Preview is the same as is the viewed project in HoloLens; all missing the additional assemblies applied in Illustrate.
Anyone any ideas?
Brian
Dec 5, 2017 2:46 PM UTC
One possible thing could be that the component is there but  is not visible. If I have some problem I will create a new  3d Model Item for a particular visible occurrence - let says "/46/12" and will check in Creo View where the display is OK  the value of the Creo View Attribute Part ID Path (actually in Creo Parametric the ProComponentpath if it is coming from Creo parametric ) and will try to change the value of the component which is not displayed (let say /46/22/3 and see if I there is an error in Strg-Alt-I (debugger mode) or if I could set the visible property to true of this Model Item.
Not sure if this will work , only a Idea.
bwhelan1-VisitorAuthor
Dec 6, 2017 10:07 AM UTC
Thanks Roland for the response. I will certainly follow that path to see it i can correct the error. I will post my findings and thanks again!
Brian
