creo not open
I am using creo 2.0, recently i am update system software, after that creo didn't open, then i am uninstall the software, then again re-install the software, again continue the problem. Is there any solution for this issue?
when we speak about Creo we need to clarify  which product? Creo View, Creo View Express or Creo Parametric?
If I  suppose that you do use Creo Parametric (the more complex product as mention above) . In this case we need to know is there some error message for example . some think like no license error ... etc. You can check in this case (Creo Parametric):
- is there a new trail file in the directory?
- is there a new entry in the std.out or std.err?
-is there a traceback.txt file?
What is the information in this files?
Regards
Roland Raytchev
