Sep 15, 2021 2:30 PM UTC
Creo View Sequence Name Bug
Hi Community,
When I use an underscore ( _ ) in a Creo View sequence name it converts it in the .pvi file to ( _5F )  when I publish the PVZ.
Example: sequence_1 becomes sequence_5F1.pvi
Thanks for fixing this bug.
Best wishes,
Alex
Sep 27, 2021 12:18 PM UTC
Hi @AlexK ,
thanks for reporting this issue to the community. I tested it and could reproduce the issue according your description with any model. e.g. I tested in Creo Illustrate 8.0.0 and could observe that in  the pvi names the underscore characters from the c3di figures names are replaced  by the string  "_5F"
But ...
When we take the published model in Vuforia Studio - in this case it works fine and displays the underscore character correctly -  e.g. :
When we have in Creo Illustrate a Figure with the name  "Figure_test_underscore" when we publish then the c3di to pvz format and later unzip the file we can see:  for the figure/sequence "Figure_test_underscore"  then the corresponding    pvi file name is "l-Creo 3D - Figure_5Ftest_5Funderscore.pvi"
But when we load the same pvz file to Studio and used it in a model widget then the sequence list property will display the correct name "Figure_test_underscore" and it will work correctly.
On the other side when I try to "correct" the name by removing the "5F" it will not work.
YEs this is a change but this change is only for  the internal pvi name (internal part of the pvz file format) . I want to remember that the name of the pvi file does not corresponds 100% to  the piv name. For example it contains also the prefix "l-Creo 3D -" so that such change when the model is working  correctly could not be classified by 100% as bug. I will ask dev team if this change was intended or not.(mistake)
My question: are there any problems which are affected by this change? Could you please, provide example where we can see that this change will affect your workflow?
Thanks!
Hi @AlexK ,
But ...
Thanks!
AlexK15-MoonstoneAuthor
Sep 27, 2021 1:46 PM UTC
Hi Roland,
Now that I know about the issue, it doesn't really bother me.
Best wishes,
Alex
