Aug 23, 2023 1:14 PM UTC
Custom Widgets Guide
do we have a workshop or a guide for "how to create advanced widgets"? Because creating simple widgets is very easy.
I've created already some custom widgets for my company, so i have experiences with that, but now i'm running in an uknown issue. I'm trying to change the bahavior of the existent BarCodeSannner. I want to be able to scan continuously until the user presses the "cancel"-button. For this i copied all needed files, renamed the needed parts so that now we have the original "scan"-widget and the copied "scan2". At the widget "scan2" i've deleted the part where the scanner stops after a successful scan. But it seems that it is failing at the initializing part. i have checked everything and followed the same steps as i did at my other widgets but it doesnt work. this why i need an advanced guide but i cant find anything.
Aug 24, 2023 12:47 PM UTC
Sorry I must of pasted wrong URL
https://www.brainshark.com/ptc/vu?pi=zGZz7CQQ9zBRxnz0
If you could provide more info - I know that there are times when the extension will not load - look into your studio logs. If you wish to share I could take a look
Aug 23, 2023 9:25 PM UTC
Did you use an existing extension as your start point? If yes
Check out this video that explores how to create an extension which allows you to get a feel for how the extensions are created - you maybe need help beyond this but if you can follow the content let me know
https://www.brainshark.com/1/content/en/portal/details/99743000?tsv=1
Aug 24, 2023 5:38 AM UTC
Yes, i made already extensions from existing widgets and it always works. I made also some widgets from scratch. I just think i miss some advanced knowledge and hope someone can help me.
For the video I have no rights to see. Is it possible to view it without registration?
