May 21, 2017 2:03 AM UTC
Customized ThingView
Hi
This is regarding Thingworx Studio. Is it possible to build my own Augmented Reality mobile app similar to Thingview using API from Thingworx Studio?
Thank you.
AB
May 22, 2017 9:16 AM UTC
Abbas Bagasra​ : I believe at this point of time this is something restricted however would confirm internally and update you. Could you please advise why you are looking for custom Views and not willing to use Standard View app. Do you feel there is some features you would like to add or have advise to improve the application UI.
Durgesh
May 22, 2017 10:46 AM UTC
Hej Abbas,
what you could do is use your own app and open the experience by url ... you could just call the certain url with the good experience from any other app.
Is it what you are searching for? Then I would explain further.
Martin
abagasra1-VisitorAuthor
May 22, 2017 12:00 PM UTC
Martin,
Basically i have an image recognition engine that will recognize certain object/sparts and then through my custom app, we can map the object to its corresponding  Thingmark and use API to send the Thingmark tag to invoke corresponding experience.
-ab
May 29, 2017 7:37 AM UTC
Hi Ab,
from what I see you could use the solution that I proposed. 🙂
Martin
