May 11, 2020 11:08 AM UTC
Date picker
Does anyone know how to make a date picker in Vuforia studio?
May 12, 2020 7:10 AM UTC
I added here the project where I tested this issue .
May 12, 2020 12:00 AM UTC
Hi  @Jeremy3 ,
so far I this possible in JavaScript we can incorporate a data/calendar picker into the Vuforia Studio environment. At least it works in preview. I did not test if this will work also o n mobile device but - I think it should.
E.g based on the follow link:
https://www.cssscript.com/tag/date-picker/
there are some data picker implmented- copy to downlaoded directory and load the lib and defined a function which is called from button:
$scope.loadjscssfile= function(filename, filetype){
 console.log("loading "+filename+":: type="+filetype)
 if (filetype=="js"){ //if filename is a external JavaScript file
 var fileref=document.createElement('script')
 fileref.setAttribute("type","text/javascript")
 fileref.setAttribute("src", filename)
 else if (filetype=="css"){ //if filename is an external CSS file
 var fileref=document.createElement("link")
 fileref.setAttribute("rel", "stylesheet")
 fileref.setAttribute("type", "text/css")
 fileref.setAttribute("href", filename)
 if (typeof fileref!="undefined")
 document.getElementsByTagName("head")[0].appendChild(fileref)
$scope.testLoad= function()
$scope.loadjscssfile("app/resources/Uploaded/lib/simplepicker.css", "css")
 $scope.loadjscssfile("app/resources/Uploaded/dist/simplepicker.js", "js")
$scope.$on('$ionicView.afterEnter', function() {
 $scope.testLoad();
 $timeout(() => { $scope.setWidgetProp("button-1","class", "simplepicker-btn");
 $scope.$applyAsync();
 },500)
//https://www.cssscript.com/material-date-time-picker-simplepicker/
// function called from a button
$scope.app.TestPicker = function()
 let simplepicker = new SimplePicker({
 zIndex: 10
 simplepicker.open();
 simplepicker.on('submit', (date, readableDate) => {
 console.warn( readableDate );
 $scope.setWidgetProp('label-1','text', readableDate);
 simplepicker.on('close', (date) => {
 console.log('Picker Closed' );
Then tested  the lib simplepicker:
Jeremy31-VisitorAuthor
May 14, 2020 3:02 PM UTC
Spoiler
Thanks for your help. It only works on AR view and not for 2D view.
May 14, 2020 3:53 PM UTC
Thanks for feedback,  but the answer is NO - it works for both - for 3D and 2D view - verified on Preivew and on android. Not sure /I did not tested on HoloLens
I attached a version of the projet where I added a 2d view.
Please, let me know if you  have questions
