Dec 30, 2016 2:56 PM UTC
Display sequence step names from Creo Illustrate
This example briefly describes how you can use the Step names that you used in Creo Illustrate sequence definitions to drive a corresponding step instruction/description in your experience. This is an unsupported, preliminary solution - R&D is working on a better, final solution. But as long as this is not available, you can use this one for PoC and demo purposes.
To setup the scene: Here is what I meant with Step names that you used in Creo Illustrate:
Now in Thingworx Studio you want to have the following result:
The text is rendered with a simple Label widget. You'll have to remember the ID of this widget for the following javascript tweak. Add the following text to the Javascript section of your View:
var labelId = "label-1"; // ID of the Label widget that displays the Step progress and description  text
// this $on event handler switches the label based on the the sequence definition
// the arg variable is of the following form: (<step #>/<total step #) <step name>
$scope.$on('newStep', function(evt, arg) {
  $scope.setWidgetProp( labelId, "text", arg); // get the currentStep from the arg
Now you only need to provide the correct initial value in the Label widget text property and add control widgets (Buttons, Playback) to drive your animation and you're done.
Easy!
Oct 30, 2018 9:01 AM UTC
Hello All,
I have managed to get the step names visible in Studio.
But I have some of those containing special character s (i.e. "é", "á"). Those are not showing correctly in the Studio preview.
Illustrate exports them fine, as I can judge from the .xlf file.
How can I get the correct values in Studio?
18-Opal
Apr 11, 2019 3:18 PM UTC
I had the same problem, and I found encoding and decoding the string seems to do the trick:
$rootScope.$on("newStep", function(evt, arg) {
 var text = decodeURIComponent(escape(arg.match(/\d*\)\s*(.*)$/)[1]));
 console.log("newStep: setting steptext to " + text);
 $scope.stepText = text;
18-Opal
Apr 11, 2019 3:37 PM UTC
Wait, I take it back. I just discovered that this approach doesn't work on many devices. Back to the drawing board...
