don´t show symbol in my animation
Why do not the symbols appear in the animation in my application? , you do not see the screwdrivers or the
arrows
18-Opal
May 22, 2018
Symbols don't transfer from Creo Illustrate to Thingworx Studio. There is a workaround, which is to add the actual symbol models to your BOM in Creo Illustrate. To do this, find your Creo Illustrate symbols library (usually in {user-directory}\AppData\Roaming\PTC\Illustrate\SymbolsLibrary\Shape), and import the *.ol model for the symbol you want into your illustration. Use this instead of the Symbols feature in Creo Illustrate, and it will carry over when you bring it into Thingworx Studio.
--Clay
18-Opal
May 22, 2018
--Clay
hi, do you have a example or video or screenshot?
18-Opal
May 24, 2018
Here are a couple of screenshots, showing loading the symbol model from the symbol library, and then showing the loaded model in the studio canvas.
