Feb 6, 2021 7:27 PM UTC
ending timeout function, with button click
Hi everyone,
i am still a rookie with JavaScript and I think this is not that difficult, but i can't find a solution.
I have an Animation, where I want to make some labels visible after some time (4.5 sec and 6.5sec) at Step 2, I use this code, which works fine:
$scope.widgets_playStarted = function(){
  if($scope.view.wdg['model-1']['currentStep'] == 2){
     $timeout(function(){
        $scope.view.wdg["label_1"].visible = true;
     }, 4500)
       $scope.view.wdg["label_2"].visible = true;
     }, 6500)
I also have a Stop-Button. With this I want to stop the animation, but I can't stop the timeout function. So when I click "Stop" the animation stops but the label still gets visible after the 4.5 and 6.5 seconds.
So how do I also cancel the timeout function with the click on the Stop button?
Thank you very much!
sebbenAnswer
Feb 8, 2021 8:40 AM UTC
you  can put an additional if statement in your timeout function like this:
 if($scope.view.wdg['model-1']['playing'] == true){
 }, 4500)
Feb 8, 2021 12:53 AM UTC
Hi, @DF_9703795
$timeout would only be executed ONCE each time it is called. And then Stop.
Base on your code, There is no need to cancel $timeout that already stopped.
Nevertheless, those Labels could be hidden by the function below, immediately.
$scope.hideLabels = function(){
 $scope.view.wdg["label_1"].visible = false;
 $scope.view.wdg["label_2"].visible = false;
 Add hideLabels() to JS Click Events of Stop Button, it should be work out fine.
Feb 8, 2021 7:55 AM UTC
@dsgnrClarK thanks for your reply.
The problem is that if I press "stop" with this function inside after the labels are visible so after the 6.5sec it works fine, but if i press stop before the labels are visible. The timeout function will still make them visible after the 6.5sec.
 Please take a look on the video I attached. When I press "X" the labels that are already visible, get hidden but after I press "X" the other labels shouldn't get visible anymore. So for that I need to stop the timeout-Function.
sebben14-AlexandriteAnswer
 }, 4500)
