Aug 1, 2022 1:59 PM UTC
Error during Vuforia Experience Server installation
I am getting an error at the end of the installation process of the Vuforia Experience Server on Windows.
This is the error that I get from the installation log:
2022-08-01T13:47:38.613Z tac:public.access.cfg Fatal Error
FATAL Error: Error creating new user 'es-authorization' statusCode: 302; undefined
at C:\ptc\.staging\node_modules\@ptc\twx-access-configurator\lib\twx-access-configurator.js:647:25
at _fulfilled (C:\ptc\.staging\node_modules\q\q.js:854:54)
at C:\ptc\.staging\node_modules\q\q.js:883:30
at Promise.promise.promiseDispatch (C:\ptc\.staging\node_modules\q\q.js:816:13)
at C:\ptc\.staging\node_modules\q\q.js:624:44
at runSingle (C:\ptc\.staging\node_modules\q\q.js:137:13)
at flush (C:\ptc\.staging\node_modules\q\q.js:125:13)
at processTicksAndRejections (internal/process/task_queues.js:79:11)
I didn't find any resourse to solve this specific issue. There are similar ones related to the Thingworx licence, but I correctly installed and verified the license on Thingworx server.
Please give me some indications on how to solve this issue.
Best regards
Aug 9, 2022 8:36 AM UTC
It seems Vuforia Experience Service install wizard has issue to create the es-authorization user in ThingWorx.
  • Can you collect and share the Vuforia Experience Service install log file, please ?
  • In ThingWorx, can you check the logs too ?
            We should have some errors reported at the same time at the 1st Augusts 2022 at 13:47:38.
Thanks in advance for your feedback.
Best regards,
Samuel
