Jun 25, 2020 6:06 PM UTC
Error VUFORIA trial installation on windows 10
I have an issue while I running the setup.exe on Windows 10 64bits:
[25/06/2020 18:33:16] System.Deployment.Application.InvalidDeploymentException (ManifestParse)
- Excepción de lectura del manifiesto desde https://studio-download.vuforia.io/downloads/Studio.application: puede que el manifiesto no sea válido o el archivo no se abra.
- Origen: System.Deployment
- Seguimiento de la pila:
en System.Deployment.Application.ManifestReader.FromDocument(String localPath, ManifestType manifestType, Uri sourceUri)
en System.Deployment.Application.DownloadManager.DownloadDeploymentManifestDirectBypass(SubscriptionStore subStore, Uri& sourceUri, TempFile& tempFile, SubscriptionState& subState, IDownloadNotification notification, DownloadOptions options, ServerInformation& serverInformation)
en System.Deployment.Application.DownloadManager.DownloadDeploymentManifestBypass(SubscriptionStore subStore, Uri& sourceUri, TempFile& tempFile, SubscriptionState& subState, IDownloadNotification notification, DownloadOptions options)
en System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl, Uri& deploymentUri)
en System.Deployment.Application.ApplicationActivator.PerformDeploymentActivationWithRetry(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
--- Fin del seguimiento de la pila de la ubicación anterior donde se produjo la excepción ---
en System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
en System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
--- Excepción interna ---
System.Xml.Schema.XmlSchemaValidationException
- El grupo de sustitución hace referencia a 'right', un elemento no declarado.
- Origen: System.Xml
en System.Xml.Schema.XmlSchemaValidator.SendValidationEvent(XmlSchemaValidationException e, XmlSeverityType severity)
en System.Xml.Schema.XmlSchemaValidator.RecompileSchemaSet()
en System.Xml.Schema.XmlSchemaValidator.Init()
en System.Xml.XsdValidatingReader.SetupValidator(XmlReaderSettings readerSettings, XmlReader reader, XmlSchemaObject partialValidationType)
en System.Xml.XsdValidatingReader..ctor(XmlReader reader, XmlResolver xmlResolver, XmlReaderSettings readerSettings, XmlSchemaObject partialValidationType)
en System.Xml.XmlReaderSettings.AddValidationAndConformanceWrapper(XmlReader reader)
I am not even able to start the installation process.
Jun 25, 2020 7:27 PM UTC
Hi @Casaga76 ,
Please review the steps given in the below article. Hope it helps to resolve the issue:
https://www.ptc.com/en/support/article/CS259459
Casaga761-VisitorAuthor
Jun 29, 2020 11:56 AM UTC
I make the steps defined in the article CS259459 but they didn't solve my issue.
In addition, the errors described don't seem to be related to my problem...
Please, could you check it again?
Regards
Jun 29, 2020 8:30 PM UTC
@Casaga76 could you please share the studio log file to track the issue. Thank you!
