Expand & Collapse Sidebar
- 7 replies
- 4317 views
- Translate All
Hi all,
I have a 2D project and I want to use a feature of expanding and collapsing the sidebar when user click on "☰ List of Instruction" button. The sidebar containing a list of instructions for assembly process using checkbox.
The idea is, after the first step being played, user have to click on "☰ List of Instruction" button to check on the checkbox for the step that has been done. After that, the sidebar will automatically collapse and the next step will automatically play the assembly process. Then the user must repeat the same step as before which is checking the checkbox and next step automatically being played.
Is it possible to do this?
Thank you in advance.
