May 16, 2019 7:06 PM UTC
Experience Service private hosting
So, I’m new to vuforia and thingworx and I’m trying to figure out some stuff.
i have a private hosted thingworx, today I installed the ES application to that server, I can see it’s created es-user; es-application key etc....
I'm running vuforia studio on a dev machine which I’m trying to connect to my ES server, I don’t know how to specify the ES server / thingworx url in studio.
Do I just <public url>.com:80/??
is this the same url to use in Vuforia View?
where do I use the es-user and es-appkey?
Also; I have a partner account but my vuforia portal hasn’t picked that connection up, how do I get them linked?
Thanks for for the help.
Paul.
May 16, 2019 7:24 PM UTC
Hi Paul,
The vuforia portal login is only for trial instances. Sounds like you have an on-prem instance, so the portal login option can be ignored.
The Experience Service uses port 2019 as a default. If you haven't changed the port during your installation process then your ES URL to enter into Studio would be <ES hostname>:2019. This would be the same for Vuforia View.
The appkeys are just used for authentication between the ES and TWX - you don't need to do anything with them.
ppierce1-VisitorAuthor
May 17, 2019 1:46 PM UTC
OK, great. Thanks.
From my ES/ThingWorx server, how to I verify that the ES has started?
May 17, 2019 4:59 PM UTC
I found the answer, in the manual (of all places)....
bin\start-es.bat
But now the question is how do I get the ES to Start automatically? Any Ideas @tmccombie
