Jun 24, 2022 9:31 AM UTC
Extension crashes Vuforia Studio
i'm trying to create my own 2D-widgets as an extension for my company.
I got OCTO_Studio_extensions and followed this simple guide.
My problem is, as soon i add any widget from the extension i will be stuck on a saving loop.
I can't preview anymore and even deleting the new widget wont help. still invinite saving loop.
Is this intended to prevent us from adding extensions or what's wrong with that feature?
Jun 27, 2022 4:43 AM UTC
First i had a gerneral problem with octo extension. But this was easy to fix => switch to a newer project. Then my own extension was on the infinite saving loop.
Now both working - I don't know what fixed my issue because i tried alot.
Even tho i used the newest version of vuforia studio i reinstalled it and started a new experience from scratch. Then i tried the extensions (the octo and my own) and both worked,
I will later test it again on an existing project, but for now that is enough for me.
cheers
Jun 24, 2022 9:43 AM UTC
Hi @AS_10340651 ,
I do not think that this should be something intended to prevent working. Possibly the extension developed in the past are not compatible with the current Studio Version - so this is a point we need to check.
When you install the Octo extensions (https://github.com/steveghee/OCTO_Studio_extensions and https://www.ptc.com/en/support/article/CS321903) is there a problem or you have the issue first with your own developed extension? Please, let me know if we have a general issue with the OCTO extension so I will ask R&D to check if there is some compatibility issue.
AS_1034065113-AquamarineAuthorAnswer
cheers
