External Data - Date&Time format
Hello friends
I need to display data in Chart from static time interval but I cannot solve how to correctly write startDate and endDate.
Can you help me?
Thanks for every respond.
Tomas
Hi @TomasCharvat ,
I think this is issue with the converting of the correct data format. Your argument/parameters  here are strings what the QueryNumberPropertyHistory service seems not to "like"
So my suggestion is to create a TWX service where you will convert / parse the string
Example:
so here the code of the TWX service - input parameters max and min as strings.
var params = {
	oldestFirst: false /* BOOLEAN */,
	maxItems: 600 /* NUMBER */,
	propertyName: 'sensor' /* STRING */,
	endDate: undefined /* DATETIME */,
	query: undefined /* QUERY */,
	startDate: undefined /* DATETIME */
params.endDate = parseDate(max, "YYYY-MM-dd HH:mm:ss.SSS Z");
params.startDate =parseDate(min, "YYYY-MM-dd HH:mm:ss.SSS Z");
// result: INFOTABLE dataShape: "NumberValueStream"
var result = me.QueryNumberPropertyHistory(params);
Then in Vuforia Studio we need to add e.g.  the TestTing custom service getChartDataMinMax
And we can test then in the preview:
Hi @TomasCharvat ,
Example:
var params = {
