11-Garnet
Mar 16, 2021 2:53 PM UTC
External Data = Thingworx Only?
If there was an existing IoT application already deployed that has relevant data for my Vuforia Experience, is there a way to get data directly from this 3rd party application, or must the data pass through a Thingworx entity property or service first and then into the Vuforia Experience?
Thanks!
Mar 17, 2021 11:14 AM UTC
So, this piece of code is running on my project:
$scope.your_api_name = function() {
 var your_url= 'http://<your_url_domain>';
 var data_on_json_format ={'name': your_name, 'surname': your_surname};
 var req = {// aggiunta Giovanni Panozzo 9.10.2020
 method: 'POST',
 url: your_url,
 headers: {
 'Content-Type': 'text/plain'
 }, data: data_on_json_format
 $http(req).then(function (response) { //chiamata api_svc_ricevicarrello
 console.log(">> OK: your_api_name");
 console.warn(response);
 },function (response) {
 console.log(">> ERR: your_api_name")
Mar 16, 2021 3:53 PM UTC
I think you could also use http get/post method for sending/receiving data.
Take a look to: https://docs.angularjs.org/api/ng/service/$http
 method: 'POST',
 url: your_url,
 headers: {
swstevens11-GarnetAuthor
11-Garnet
Mar 22, 2021 6:42 PM UTC
Thanks.  I'll give it a try.
