Jun 10, 2019 5:04 PM UTC
facing problem while uploading file which is having size more than 100mb
I am creating an AR of big plant but i was unable to upload file on vuforia studio because it's is having file size more than 100mb and it's taking hours to upload and even it doesn't respond in the end.
Can any one help me for the same.
Thank you
Jun 11, 2019 7:39 AM UTC
  • Did you try to reduce size of the file ?
For example by using a shrinkwrap or remove all 3D Models who are not visible.
  • Did you try to decrease the quality of the model ?
Sometime, decrease the quality of the model is not visible in 3D application and is enougt to reduce size of the 3D Model.
  • Did you try to split the 3D model in mulitple files ?
Best regards,
Samuel
nraichura1-VisitorAuthor
Jun 11, 2019 7:46 AM UTC
Dear Samual
I have tried shrink wrap of assembly ,used cad optimisation and while assemly is getting optimised up to low leval log shows unhandled error in cad optimisation.
Actual size of my assemly and pvz is too much I have already optimised it.
Thank you
Jun 11, 2019 7:51 AM UTC
  • What is the exact versbose reported in the log file ?
  • What is the original 3D model file type before the conversion into pvz file ?
Best regards,
Samuel
