Failed to authorize experience server
Hi:
I'm facing this issue every time I try to publish or validate, uninstalled and installed several times but nothing helps.
hoping to get a quick solution.
thanks for your time.
nv-2Answer
I uninstalled and installed again and used other account to login then changed that login details now its working fine. and the logs file restarted so unable to send you.
Thanks for the support!
Hi @nv-2 ,
To validate that the correct set of credentials are used while accessing the ES URL, enter the ES URL into a web browser in the below format:
https://<es-url-hostname>/ExperienceService/username
This URL requires authentication and should display your username in the browser window after successful login.
Also, please share the studio log file to track the issue.
nv-21-VisitorAuthor
This is the error from logs:    [2019-05-20T03:46:16.067Z] error: [twx-studio:auth:oauthHandler] tunneling socket could not be established, cause=socket hang up
GET /api/validate 500 1710.449 ms - 38
the user name is getting displayed when im trying this: https://<es-url-hostname>/ExperienceService/username
Are you using any proxy server on your network? If you are using a proxy, please enter your proxy information within studio settings.Screenshot_8.png
