Feb 22, 2019 9:10 AM UTC
File Driver in iOS
Hi .
I am trying to create file driver for iOS Platform , After following document i am able to generate build, i found that Driver.h file is missing in VuforiaSDK  for iOS. this is blocking us going forward in implementation.
Can you Please help me on this.
Thanks in Advance.
Feb 22, 2019 12:18 PM UTC
Hi @gi395923 ,
I do not think that this is the correct community for this quesiton / (or at least it is not yet)
So far I know
The functionality  of the Vuforia SDK is directly supported  on the Vuforia Developer portal
The  Support portal – the Support center:
https://developer.vuforia.com/support
And the support forums :
https://developer.vuforia.com/forum
In the Forums  you can directly report a problem with the Vuforia SDK -> create a new Topic for your issue
So I think this should be the correct area for this particular problem: https://developer.vuforia.com/forum/ar-technical-discussion/android
For  Vuforia Engine issues could be reported on the following link /PTC Web Page:
https://developer.vuforia.com/support/contact/cloud
Of course if some community member has experience in this matter is wellcome to help.
Hi @gi395923 ,
So far I know
