May 18, 2018 11:36 AM UTC
Freeze animation
is it possible to stop an animation immediately?
In my case the animation just play the sequence till the end after clicking the stop button.
Thank you,
Jonny
Jonny1-VisitorAuthor
May 25, 2018 9:55 AM UTC
FYI: I found the JavaScript command stopping the animation.
scope.stop = function() {
 // currently "stop" will only stop playback of a playAll when it reaches the end of a step.
 scope.continuousPlayback = false;
 The stop function is not programmed to stop or to pause the animation immediately.
18-Opal
May 25, 2018 3:31 PM UTC
Have you tried calling the Reset service on the model?
$scope.app.fn.triggerWidgetService('model-1','reset');
--Clay
May 28, 2018 6:55 AM UTC
Hey Clay,
the "reset-service" will reset my complete sequence. In my case I need a function that just pause the animation like a video player or like it is possible in Creo Illustrate.
18-Opal
May 31, 2018 3:30 AM UTC
Ah, I see, I thought you wanted to completely stop the playback, not just pause it. I haven't found a way to do that.
--Clay
