Nov 21, 2023 8:09 AM UTC
Geting Model Position
Dear Community
I've found some code to get the position of an assembly part here:
https://support.ptc.com/help/vuforia/studio/en/index.html#page/Studio_Help_Center/cad_structure_api.html
But it doesn't seem to work for me
$scope.centerof = function() {
// Get the Structure information for model-1
 PTC.Structure.fromId('model-1').then ( (structure) => {
 // Get the properties of the 'model-1' widget
 var widgetProps = $scope.view.wdg['model-1'];
 // Get the bounding box information for part '/0/0/2'
 var bbox = structure.getBounds('/0/0/2');
 // Transform the bounding box to account for the 'model-1' widget's location
 var xform_bbox = bbox.transform(
 [widgetProps.x, widgetProps.y, widgetProps.z],
 [widgetProps.rx, widgetProps.ry, widgetProps.rz],
 widgetProps.scale);
 // Move '3DImage-1' to the center of the bounding box
 $scope.view.wdg['3DImage-1'].x = xform_bbox.center.x;
 $scope.view.wdg['3DImage-1'].y = xform_bbox.center.y;
 $scope.view.wdg['3DImage-1'].z = xform_bbox.center.z;
 // Get the location information for part '/0/2/8'
 var loc = structure.getLocation('/0/0/2');
 // Transform the location to account for the 'model-1' widget's location
 var xform_loc = loc.transform(
 widgetProps.scale);
 // Get the rotational component as euler angles
 var rot = xform_loc.rotation.asEuler();
 // Rotate '3DImage-2' to match the rotation
 $scope.view.wdg['3DImage-1'].rx = rot.x;
 $scope.view.wdg['3DImage-1'].ry = rot.y;
 $scope.view.wdg['3DImage-1'].rz = rot.z;
I've added a demo experience to troubleshoot the issue.
Does anyone know what's wrong?
Best wishes
Alex
Nov 21, 2023 11:46 AM UTC
Hi @AlexK ,
possibly the project used old template. Also there was no meta .json file - at least I did not find such after I  imported the project to Vuforia Studio. So I  tested it ( with   Vuforia Studio 9.15)-
One point is that all the  parameter objects  should be an array from 3 items (also the scale) according to the PTC Studio Help.  so changed it e.g.:
 console.log("bbox")
 console.warn(structure.getBounds('/0/0/2'))
 posArr=[]
 posArr.push(widgetProps.x);posArr.push(widgetProps.y);posArr.push(widgetProps.z)
 rotArr=[]
 rotArr.push(widgetProps.rx);posArr.push(widgetProps.ry);posArr.push(widgetProps.rz)
 scArr=[]
 scArr.push(widgetProps.scale);posArr.push(widgetProps.scale);posArr.push(widgetProps.scale)
 var xform_bbox = bbox.transform(posArr,rotArr,scArr);
So now  it seems to work. Here the modified project attached to the post.
I think to get the (new ) functionality to work you need to start  with the latest version and create a new project. I did not  see this functionality  before. Because I remember that in previous    versions we needed to use an TWX extension to extract the bbox data . I remember that such requirement was reported as enhancement to R&D Team and now is really  good to know that it is already implemented in the current functionality !
Hi @AlexK ,
 console.log("bbox")
 posArr=[]
 rotArr=[]
 scArr=[]
AlexK15-MoonstoneAuthor
Nov 21, 2023 12:06 PM UTC
Hi Roland
Thank you very much, your version works great! I did have to update my studio version to make it work.
Best wishes
Alex
