May 21, 2019 8:18 AM UTC
Got stuck with the Thingworks Server URL
Got stuck with the installation of experience service. What Should I do when it is asking me for the Thingworks Server URL and credentials? Can't find anything in the document; it only gives an example but where do we get it from?
May 21, 2019 8:30 AM UTC
Adding @Durgesh :
Hello @Durgesh  : Could you please help here.
Avinash
May 21, 2019 2:20 PM UTC
@J.V.Madhavan  It is important to understand that Vuforia Experience Service (ES) runs on top of ThingWorx. So,  basically, you need to have a ThingWorx instance already setup or can install now which could be associated with your On-premise ES. Once you have the ThingWorx instance then post running ES setup enter the ThingWorx Administrator user credentials & ThingWorx URL ( e.g. http://<Server Name or IP>:<Port>/ThingWorx )to proceed further with ES setup.
Also, make sure you go through the compatibility matrix details outlined in Install and deploying an Experience Service document.
I hope it clarifies your query.
-Durgesh
May 22, 2019 11:50 AM UTC
Thank U Durgesh, To have a thing work instance what should I have to install. In our software downloads list I'm able to see the following downloadables.
May 22, 2019 1:26 PM UTC
@J.V.Madhavan  You will need to install ThingWorx Platform.
