Aug 9, 2017 11:00 AM UTC
grouping the model items into single item in thingworx studio
Is there any way to group 2 or more model Items into single items. so that the 2 or more parts will act as single part. if not possible how can i achieve ?
thanks in advance
Aug 9, 2017 8:42 PM UTC
Hello, Prasad Reddy.
I've asked our ThingWorx Studio engineers to look into your question. You should be hearing something more detailed soon.
-- Craig A.
7-Bedrock
Aug 10, 2017 6:03 AM UTC
Hi, check this thread for the case opened requesting that functionality.
How do I set the origin of scaling a 3D model​
It would be great if we can get this soon, it would definitely speed up authoring of more complex experiences.
Aug 19, 2017 9:24 AM UTC
Hi Prasad,
in fact your case could most likely be addressed by
  1. re-arranging the assembly structure in CreoIllustrate so that the components that you want to move together are in one parent assembly node
  2. Create a ModelItem for this parent node. You may not be able to directly pick it but only select one of its childs but then you can change/shorten the component path attribute value to get to the common parent assembly.
I hope this answer was detailed enough!
Cheers, moritz
preddy-41-VisitorAuthor
Aug 21, 2017 11:36 AM UTC
Hi Moritz von Hasselbach,
Thanks for the kind reply, is there any trial version available for the Creo illustrate to work on ? if yes please share the link. i have gone through the whole PTC site for trial version but I am not able to get it. it will be helpful if I can get the trial version
Jan 18, 2018 5:12 PM UTC
yes it is - use creo illustrate for that -
depending on your model structure / data quality you can already do that by modifying the occurence id of that model item - but you can check back in a tool like illustrate / or creo view.
