Aug 28, 2018 9:09 AM UTC
Hardware requirements for Spatial Target experiences on Android devices
Hi!
I have noticed that Spatial Target experiences does not work on all Android devices (v5+).
Is there any list describing which devices are supported?
Or, if not, what should I consider choosing a device for ST experiences?
Thanks in advance!
dupatelAnswer
Aug 28, 2018 9:19 AM UTC
@IstvanPolacsek You can refer to Product Help center documentation for latest details. Also, check out the Vuforia supported device list for Android, iOS and Windows.
-Durgesh
dupatel5-Regular MemberAnswer
-Durgesh
Aug 28, 2018 10:20 AM UTC
@dupatel Thank you very much!
I see that the Android device list contains mostly Phones.
Do you have any information about:
  • How often does this list being updated?
  • Is there any plan to include Tablets as well?
Aug 28, 2018 2:07 PM UTC
As i understand it Spatial Tracking depends on Ground Plane support in AR Kit (Apple) or AR Core (Android). Ground Plane support requires a minimum set of sensor (6-axis IMU) AND a per device calibration file produced by the phone manufacturer. This is why you see wide support on Apple as they only make a few devices and they are the OEM and the developer evangelizing AR Kit. Android required every OEM to create a calibration file for their devices and as we see with OS updates on Android many OEMs are reluctant to do anything for a device after the initially ship it. This is why Google and Samsung dominate that supported device list.
