Feb 8, 2018 3:36 PM UTC
Hi I would like to know
How can I connect Twx Studio to another database platform, other than Composer?
Feb 8, 2018 3:49 PM UTC
Dul Flores​: You can do that using ThingWorx where you can have configuration to connect external databases. Also, can write custom services to make REST call and then pull data from external system. Once you have data in Thingworx , then it can be easily be used inside ThingWorx Studio.
-Durgesh
dflores-21-VisitorAuthor
Feb 8, 2018 6:25 PM UTC
There is some other way to import data in real time, if you do not use the Thingworx composer platform?
Feb 9, 2018 5:17 AM UTC
Dul Flores​: I believe we do not allow this at the moment and one way is to use ThingWorx to access external system.
-Durgesh
