Jan 11, 2021 1:53 PM UTC
Hide parent of component
Hi everyone,
in my project I'm able to access metadata of PVZ and hide/unhide a selected component.
So, how I could hide the parent of the selected component?
For example, If my Bom is something like:
/12512/325/12
/12512/325/13
/12512/325/11
/12512/325/100
When I selected 12 or 13 or 11 or 100 I want to hide all 325 groups. How could I access to this information?
Thank You.
Jan 11, 2021 8:38 PM UTC
So for I remember (I am not 100% sure) in  some demos I saw in the past there was some usage like this
- to hide all components in the model-1 widget
tml3dRenderer.setProperties('model-1-/', { decal:false, hidden:true });
to model-1 with path 0-0-6 and the comp level below to set hidden and the decal
Here example to set also the shader (depending on mode preview or mobile) , decal and hidden
tml3dRenderer.setProperties('model-1-/0/0/6', { shader:twx.app.isPreview()?"Default":"xray2;cutoffDepth f 0.25", decal:false, hidden:true, opacity:0.99 });
example
tml3dRenderer.setProperties("model-1-/12512/325", { hidden:true });
or
tml3dRenderer.setProperties("model-1-/12512/325/", { hidden:true });
I think the first example will hide the comp path /12512/325
and the second will hide all component in the next level below- I think the effect will be the same but later you can change the hidden for subcomponent.
Because I did not test now by myself so if it will not work then,please, let me know so I  need to check it more detailed
