Oct 11, 2019 1:23 AM UTC
How can i change my font size to responsive
i am trying to change my font size to responsive, so that it will be able to view the complete text in any devices.
For example,
Thanks in advance 😀
sdidierAnswer
Oct 11, 2019 8:03 AM UTC
Hello Benchan,
I have tested this solution with StyleSheet :
https://www.w3schools.com/howto/howto_css_responsive_text.asp
It seems works fine.
Please find attached an example Project.
More details about this example :
  • In 2D Canvas, a Grid and a Label Widgets have been added
  • Grid Widget is to control the size of the Label
  • If the text has a big size in a big screen, it can be truncated
  • In PROJECT Panel, in STYLES > Application, this CSS has been added :
.label_font_size_responsive {
 font-size:10vw;
  • This CSS class is used in the Label Widget in the Property named Class
  • We entered this value label_font_size_responsive
  • Is it helping you ?
Best regards,
Samuel
sdidier17-PeridotAnswer
Hello Benchan,
 font-size:10vw;
Best regards,
Samuel
benchan951-VisitorAuthor
Oct 14, 2019 11:39 AM UTC
Thanks alot samuel, it works perfectly!! 😀
