Feb 4, 2020 7:11 AM UTC
how do i set a timer
Hi all,
I am currently developing a project that requires a timer in the UI. Which means, once the experience is launch, the timer will automatically start. This is to track the amount of time needed for the technician to finish the task. But how do i code this function to the value?
Feb 4, 2020 10:18 AM UTC
Hi @benchan95 , @
I think you can find directly information for one possible solution in the current Vurofia Studio  help center - following link:
Use a Timer in JavaScript
Hi @benchan95 , @
benchan951-VisitorAuthor
Feb 6, 2020 7:36 AM UTC
Hi Roland,
Problem is solved. Thank you!
