How does ThingWorx Studio set to rotate in 360 ° when viewed in ThingWorx View ?
    Need to achieve the following results in ThingWorx View, I would like to ask how to achieve in ThingWorx Studio, whether the relevant information reference.
           1. Support 360-degree rotation to view the contents of the release
           2. Support to manually zoom in or out to view the contents of the release
           3. Scroll through the text message
Ju Bin Liang​ I would suggest to refer the article - How to rotate the 3D model in Experience View - for 360-degree rotation. similarly, you can make use of binding the 'Scale' property to zoom.
Giri
lliangjb1-VisitorAuthor
Hi,giri:
     The current 360-degree rotation and zoom can be achieved through the slider control, will ThingWorx View support not to display controls, and directly manually drag the model on the screen,zoom in and out by two fingers?
Manual drag-n-drop and zoom in by two fingers doesn't work as of now.
Giri
