6-Contributor
Sep 11, 2018 1:59 AM UTC
How the appConfig.json file act ?
How the file appConfig.json act? The file in every projection files , such as C:\Users\Administrator\Documents\VuforiaStudio\Projects\demo1.
My studio run some *.pvz files, the appConfig.json file will disappear, the studio get stuck, report errors
mgoelAnswer
Oct 18, 2018 6:26 AM UTC
@Jack86
Hope you are doing good. Could you please confirm if the issue has been resolved.
If yes, please mark the answer as accept as solution for the future reference. Thank you in advance.
Regards-Mohit Goel
Sep 11, 2018 2:06 PM UTC
I have never seen this file disappear before.
Looking at one of mine it seems to contain the settings from "Configuration" section of the left pane: Themes, Experiances and Info.
So if it's gone i can see the project not loading. What do yo mean by "run some .pvz files"? Are you uploading them?
Jack866-ContributorAuthor
6-Contributor
Sep 12, 2018 12:56 PM UTC
Thank you for your answer.
"run some .pvz files" means that add model into studio.
I have tried some times again,  maybe the problem is*.pvz files. I change another model is OK.
mgoel5-Regular MemberAnswer
@Jack86
Regards-Mohit Goel
