How to colorize a panel?
I know this is probably a pretty basic question, but how do you change the panel in an experience to not be transparent?
    shumphrey1-VisitorAuthor
    Ok.  I have figured out that I need to use CSS.  I have put this in the Style Application .panel-white {background: rgb(255, 255, 255);}
    Where do I reference this so that it uses it?
    I figured it out.  I just had to put the style name in the column class reference.
