How to connect Thingworx platform with Vuforia Studio?
Also pls let me know what are the pre-requisites of doing above process. Please provide all the supported links and documentation also.
If any Experience Service extension is required to download then please let me know the name of that extension too.
Thanks in advance.
saroraAnswer
If it is onPremise, they you need to install experience server for the studio to work.
But before installing experience server, you need to have the db setup and Thingworx installed on your machine.
Have you already installed Thingworx? If not, please follow the below guide to install db and Thingworx. https://www.ptc.com/support/-/media/860FD42193E045D297468C7BBA334F73.pdf?sc_lang=en
Once done with the Thingworx installation, please find below the guide to install the experience server(Skip this step if ES is ptc hosted)
Experience Service Help (ptc.com)
After completing the above steps, you can start working with studio
Vuforia Studio Help (ptc.com)
Hope this helps.
sarora5-Regular MemberAnswer
Hope this helps.
