Dec 20, 2019 6:29 AM UTC
how to copy entire view from one project to another new project in vuforia studio?
Dec 20, 2019 1:13 PM UTC
so far I know currently there is no supported functionality to do this but you can try the following.
- let say you have defined a project with 2 views : Home and SECOND_VIEW
- let say you want to copy the SECOND_VIEW to other project.
Steps:
1.) copy the SECOND_VIEW.js and SECOND_VIEW.json form the
<your USER directory >\VuforiaStudio\Projects\<SOURCE project>>\src\phone\components to ...
<your USER directory >\VuforiaStudio\Projects\<Target project>>\src\phone\components to ...
2,) I think this above is all but to be sure, you can  additionallly   eddit in the  directory
<your USER directory >\VuforiaStudio\Projects\<Target project>>\ appConfig.json
so here you need to edit  appConfig.json and add the second view:
"targets": {
 "phone": {
 "components": [
 "name": "Home",
 "fileName": "Home",
 "showInMainMenu": true,
 "viewType": "ar",
 "title": "Home"
 "name": "SECOND_VIEW",
 "fileName": "SECOND_VIEW",
 "viewType": "mobile-2D",
 "title": "SECOND_VIEW"
 then go and open the Target project in Studio UI. It should update the project.
A related issue is reported in the post duplicated a view
Steps:
"targets": {
 "phone": {
 "components": [
 "name": "Home",
 "fileName": "Home",
 "viewType": "ar",
 "title": "Home"
InfinityX1-VisitorAuthor
Dec 21, 2019 5:48 AM UTC
thanks for reply. this solution helps a lot and it saves the time during creating experience. I tried this solution personally and its working fine.
only one thing i want to add is we need to copy paste the resources from original project to new project
