Jan 27, 2020 7:50 AM UTC
how to delay a popup
hi,
is there a way to extend the timer of showing a popup?
Jan 27, 2020 8:35 AM UTC
Hello Jc2,
I think that a custom Javascript function to close a popup is possible by using a timer.
To close a popup, use this code :
$scope.view.wdg['myPopupName']['visible'] = true;
To close a popup after 1 second, I will use a similar function to that :
$scope.hidePopup = function () {
 $timeout(function() {
 $scope.$broacast( 'view.wdg['myPopupName']['visible'] = true' )
 }, 1000);
Call the hidePopup function when opening the popup. For example when clicking the button who opens it.
Best regards,
Samuel
Mar 12, 2020 12:30 PM UTC
Hello @sdidier,
                            Thank you for the code, but I am facing syntax error and it is not working. Could you please check the mentioned code. Regards
