May 14, 2019 8:58 AM UTC
How to find Log files logfile.txt
Hi, this is not by me. I just copied it from the ptc knowledge base. Might be helpful.
iOS
  • Connect your device to a computer with iTunes on it
  • In iTunes, select the device
  • Select File Sharing in left side menu
  • Select View in list of apps
  • Drag logfile.txt to desktop
Android
  • Log files are located under Android folder
    • ..\Documents\Vuforia View\
  • logfile.txt is the most recent log
Windows Surface
  • Log files are located at C:\Users\{userName}\AppData\Local\Packages\9CAFC431.VuforiaViewEnterprise_fvvfpfxfdh1zr\LocalState\
  • File is named log<date>.text
HoloLens
  • Open a web browser
  • Navigate to device portal by entering the IP address of HoloLens
  • Select File Explorer > Camera Roll from left side menu
  • Download latest log file
    • Vuforia View must be closed to download log file
May 14, 2019 8:59 PM UTC
Thanks for posting this, @whity
Here is the Knowledge Base article for everyone's reference: https://www.ptc.com/en/support/article?n=CS283816
