Jun 26, 2023 12:51 PM UTC
How to install JS extension
Hello Community
I am trying to set up a password verification in Java Script and I need to use a external library for the hashing. How can I define the CryptoJS.md5 function that is used in the code below?
//functon for loading of javascript and css
$scope.loadjscssfile= function(filename, filetype){
 console.log("loading "+filename+":: type="+filetype)
 if (filetype=="js"){ //if filename is a external JavaScript file
 var fileref=document.createElement('script')
 fileref.setAttribute("type","text/javascript")
 fileref.setAttribute("src", filename)
 else if (filetype=="css"){ //if filename is an external CSS file
 var fileref=document.createElement("link")
 fileref.setAttribute("rel", "stylesheet")
 fileref.setAttribute("type", "text/css")
 fileref.setAttribute("href", filename)
 if (typeof fileref!="undefined")
 document.getElementsByTagName("head")[0].appendChild(fileref)
// Enter the View
$scope.$on('$ionicView.afterEnter', function() {
 /*$scope.loadjscssfile("app/resources/Uploaded/picker/lib/simplepicker.css", "css")*/
 $scope.loadjscssfile("app/resources/Uploaded/md5.js", "js");
function generatePasswordHash(password) {
 var hash = CryptoJS.MD5(password).toString();
 console.log(hash);
 // Use the generated hash as needed
var password = 'myPassword123';
generatePasswordHash(password);
Thanks for your help.
Best whishes
Alex
Jun 26, 2023 5:16 PM UTC
This a little complex loading lots of files plus that archive is old.
Maybe you could use https://cdnjs.com/libraries/crypto-js
get the js downloaded as one file and then
const cryptoscript = document.createElement('script');
cryptoscript.src="app/resources/Uploaded/cryto-min.js";
document.head.appendChild(cryptoscript);
cryptoscript.onload = function() {
console.log(hash);
console.log(hash);
AlexK15-MoonstoneAuthor
Jun 27, 2023 1:23 PM UTC
Hi Steve
Thanks for your reply.
I am still getting this error: "Uncaught ReferenceError: CryptoJS is not defined"
Do I need to make changes to the js file so the CryptoJS is defined?
I've uploaded the Project file.
Best wishes
Alex
Jun 30, 2023 1:51 PM UTC
Hi Alex,
I have imported your "Login_Test_Project" and I noticed that the md5.js file is totally empty. This is the issue.
Try to fill the file with the text contained in this link: https://cdnjs.cloudflare.com/ajax/libs/crypto-js/4.1.1/crypto-js.min.js
and retry. It should work
