7-Bedrock
Mar 12, 2018 6:12 AM UTC
How to invoke the widget service programmatically using js in Thingworx Studio?
I will like to invoke the 'showpopup' service of 'Popup' widget from the js function instead of using 'click' event binding.
yleongAnswer
7-Bedrock
Apr 18, 2018 10:40 AM UTC
I have found the answer by exploring $scope.app object.
The $scope.app do provide property 'fn' that includes the function called triggerWidgetService(widget_id, service_name).
The sample script for reference.
$scope.showPopup = function(){
$scope.app.fn.triggerWidgetService('popup-1','showpopup');
Apr 2, 2018 9:19 PM UTC
Hi @yleong
Could you please provide more details on this scenario? Would you like to invoke the show-popup service from another function written in js file?
yleong7-BedrockAuthor
7-Bedrock
Apr 11, 2018 6:20 AM UTC
Example when a model item is selected, click event will trigger an js function. The function will performs some validation like check current step, after the validation i will like to use js to trigger the 'show popup' service of the new pop-up widget  inside the function. I will like also to use js to trigger the 'play' service of audio widget.
Apr 17, 2018 4:31 AM UTC
Here is my suggestion:
  • Edit the <<viewname>>.js file and add a showPopup function to your view that will display or hide your popup:
    $scope.showPopup = function(flag) {
     $scope.view.wdg['yourPopUpName']['visible'] = flag;
  • Replace 'yourPopUpName' with the name of your popup (case sensitive)
  • Save the <<viewname>>.js
  • On you JS Trigger, call the function passing True or False to Display or Hide the PopUp:
    showPopup(true); // Display PopUp
    showPopup(false); // Hide PopUp
Hope it helps,
Ricardo
